    Hi, I first posted this 4 days ago with no replies yet, maybe I got the wrong Forum, here it is again..
    I am building my own CNC wood router, for cutting and shaping guitar bodies and other wooden parts, I have limited space in my man cave, so I have gone with an initial design with a work area of 800mm x 600mm using 16mm Linear Rails. My problem is I cannot decide if I should use NEMA 17's or NEMA 23 's, Stepper Motors, mainly because NEMA 23's appear a lot more expensive than NEMA 17's (I am retired on a Pension) The hardest wood I will be cutting will probably be Alder & Basswood for the bodies, I sometimes use Mahogany, Maple or Rosewood for Guitar Fingerboards, this usually involves very little heavy work
    All advice would be gratefully appreciated, I hope I have provided enough information.
    Regards.
    Ray
    If you don't want to be disappointed later I would go with the NEMA 23s.
    I built a machine for the same purpose but went for 900 x 600 due to similar lack of space.
    My build log is here if you are interested, https://www.mycncuk.com/threads/6565...9344#post49344
    Many thanks, that's what I initially thought, I will just have to save up a bit more money.
    Hi Ray, welcome to the forum!
    Sorry i did mean to reply to you, doh! life gets in the way.
    Anyway, defo Nema 23's, and here is why: Sticky: What size stepper motor do I-need.
    This was found in the:
    Stepper & Servo Motors
    Discuss Servo Motors or Stepper Motors and other related topics here.
    80-Stepper-Servo-Motors
  1. Reverse stepper motor direction on driver/motor winding
    By Nemo1966 in forum General Discussion
    Last Post: 07-08-2024, 03:25 PM
  2. Replies: 11
    Last Post: 02-10-2020, 09:49 PM
  3. larger stepper motor needed
    By terry1956 in forum General Electronics
    Last Post: 29-05-2017, 05:35 PM
  4. Replies: 10
    Last Post: 13-03-2015, 12:25 PM
  5. Replies: 1
