    Hi.
    Thanks to members of this site I have decided to build my CNC wood router using NEMA 23 stepper motors. Due to space restraints in my workshop I have decided to build a Floating bed, Fixed Gantry frame, so I need x3 Steppers. I already have several Arduino Uno's I can use, but I understand the Arduino CNC shield can only handle up to 2 amps each, the NEMA 23's will probably be 2.8 amp. Does anyone have any advice on this? I have Googled this problem but things seem a little confusing. Do I use the Steppers with there own Driver, can anyone supply me with a wiring schematic I may study??
    Regards.
    Ray
    Ray,
    I feel you are on the path of building a 'toy' cnc machine.
    You need to do more research, start by looking through some of the build logs on this forum, there are plenty of schematics to be found. https://www.mycncuk.com/forums/253-D...ter-Build-Logs
    Hi, Thanks for the reply. "TOY" maybe to you, but a serious piece of kit for me. I first used a CNC milling machine in 1968, during my apprenticeship, I have been fascinated by them ever since. Its not mechanicals that bother me, but as my thread states I need electronic help, The threads you have pointed me to look mainly mechanical build, Bit I will Plough through them.
    Regards.
    Ray
    Lives in Plymouth, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    We all have to start somewhere - my first CNC router was to a slightly modified version of the JGRO design (details available with a quick Google search). Built from MDF, leadscrews were screwed rod from Screwfix, 3D printed blocks to hold bearings (which were an upgrade from the original design's MDF blocks!) and many other nastinesses. But, despite being thrown together in a hurry to carry out a commitment I had rather rashly made, it worked and taught me a lot. Not least that MDF has the long-term structural integrity of cold-rolled cow dung...
    The current Mk2 is all steel, welded construction, Hiwin profile rails, ballscrews, etc. A completely different beast but which drew heavily on my initial learnings. It also reused the Nema23 motors and 2.2KW water-cooled spindle I had rashly over-specced for the Mk1 as I had this vague idea of a future upgrade. Go for it - you can always build a Mk2 if you need it! I described my Mk2 on this forum a few years ago - it's here: https://www.mycncuk.com/threads/1161...highlight=avor.
    I certainly don't want to garner any animosity or disrespect by using the word "toy", but the reason for my comment was twofold
    1. From your comments I assumed you wanted the cnc machine to do the required job of making guitars. I have made quite a few guitars among other things and I know the amount of rigidity and spindle power that is required to do the job and in a timely manner. You could build a lighter machine that would probably work but you might be dissatisfied with the result so I'm trying to encourage you to avoid that.
    2. I'm assuming you want version 1 of the cnc machine to do the job rather than embarking on a version 2 later, why do you think others have had to build a version 2 ?
    If you want to build a cnc machine for learning purposes then Neale's reply might be more applicable. Best of luck either way.
    A search on the internet for "cnc schematic" produces loads of hits.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    To answer the main question, you can use an Arduino to only provide the step/direction pulses to a typical stepper motor driver, although you may need a buffer board to boost the switching voltages (can be done on some basic stripboard).
    The CNC shields typically use drivers with limited current and voltage limitations (voltage is needed for speed, and for any decent machine, you'll likely be best with at least 36V)
    I'm personally not a fan of arduino based controllers, but they do do the job. Although not likely at the quickest speed.
    Ultimately you need something to generate step/dir signals, which are then fed into the stepper motor drivers.
    How that's achieved depends on what exactly you're planning on using.
    Hi again, no animosity taken.
    Has previously stated, I am not a novice at CNC, my first CNC was a converted "HOBBYMAT BFE65" desktop milling machine, this was about 12 years ago, may be more. I fitted Steppers to this machine, X.Y & Z Axis, it ran on MACH3 and a Desktop PC, a DELL if I remember right. It worked perfectly well, only used it a few times, small parts made. I was then given an offer I could not refuse. I was offered double the money I had spent, a no brainer at the time, as my hands and skeleton where then OK, and I could still use hand tools, since then of course Arthritic has set in in both hands and I now find it difficult to use them, with hindsight I wish I had kept the machine, built another with the money I made, and simply learned more about programming etc; then I might not have to ask many questions.
    What can you recommend m_c ?
    Regards
    Ray
    The stepper motor break out board I used is made by Planet CNC. Being an Apple and Linux user I had to find a board that not only worked with Windows. The great thing about this board is the fact DWG files can be sent directly without a toolpath generator . This board works really well with Kirimoto CAM toolpath (freeware) software for STL files.
    I assume you need a 3 axis controller for your project.
    Planet cnc make boards for 3 to 9 axis machines!
    Quote Originally Posted by The Gresley Luthier View Post
    Regards
    Ray
    For which part specifically?
    Controller, or drivers?
  1. Reverse stepper motor direction on driver/motor winding
    By Nemo1966 in forum General Discussion
    Last Post: 07-08-2024, 03:25 PM
  2. Stepper motor drivers or Ardunio stepper motor drivers
    By Sid in forum Gantry/Router Machines & Building
    Last Post: 11-04-2022, 01:31 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
