    I certainly don't want to garner any animosity or disrespect by using the word "toy", but the reason for my comment was twofold
    1. From your comments I assumed you wanted the cnc machine to do the required job of making guitars. I have made quite a few guitars among other things and I know the amount of rigidity and spindle power that is required to do the job and in a timely manner. You could build a lighter machine that would probably work but you might be dissatisfied with the result so I'm trying to encourage you to avoid that.
    2. I'm assuming you want version 1 of the cnc machine to do the job rather than embarking on a version 2 later, why do you think others have had to build a version 2 ?
    If you want to build a cnc machine for learning purposes then Neale's reply might be more applicable. Best of luck either way.
    A search on the internet for "cnc schematic" produces loads of hits.
    Hi again, no animosity taken.
    Has previously stated, I am not a novice at CNC, my first CNC was a converted "HOBBYMAT BFE65" desktop milling machine, this was about 12 years ago, may be more. I fitted Steppers to this machine, X.Y & Z Axis, it ran on MACH3 and a Desktop PC, a DELL if I remember right. It worked perfectly well, only used it a few times, small parts made. I was then given an offer I could not refuse. I was offered double the money I had spent, a no brainer at the time, as my hands and skeleton where then OK, and I could still use hand tools, since then of course Arthritic has set in in both hands and I now find it difficult to use them, with hindsight I wish I had kept the machine, built another with the money I made, and simply learned more about programming etc; then I might not have to ask many questions.
There are currently 12 users browsing this thread. (0 members and 12 guests)
  1. Reverse stepper motor direction on driver/motor winding
    By Nemo1966 in forum General Discussion
    Last Post: 07-08-2024, 03:25 PM
  2. Stepper motor drivers or Ardunio stepper motor drivers
    By Sid in forum Gantry/Router Machines & Building
    Last Post: 11-04-2022, 01:31 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
