    Hi all.
    After many days of reading and researching, I may have made up my mind what Stepper Motors and Drivers to get for my self built CNC.
    I have taken advice and picked NEMA 23's for all Axis & DM556T for all Drivers, my only concern now is which power should I choose, 1.8, 3.0 Nm bearing in mind I will mainly be cutting wood for my guitar bodies, sorry to be a pain, but I need to get this right first time due to cost restraints.
    Also do I need Bi Polar or Unipolar, Hybrid, all very confusing.
    Regards.
    Ray.
    Last edited by The Gresley Luthier; 15-01-2026 at 05:09 PM. Reason: Additional Info.
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'd probably er on the higher torque side, and go for the 3.0Nm motors, certainly on the X and Y, as that's the axes that will be worked the hardest.
    Z axis isn't usually worked quite as hard, so is usually more dependant on how heavy your Z-axis assembly is going to be, so the smaller motor may be good enough, although if you have the space, there wouldn't be any real downside to a larger motor.
    Most modern steppers are technically Hybrid motors.
    Bi Polar/Uni Polar depends on how they're wired, but for DM drivers you'll want them Bi Polar, and typically wired in parallel (that's if the motors are 8 wire. Some are only 4 wire so you don't get an option between parallel/series, and some are 6 wire for UniPolar/Series use only)
    The key specification you want to look at, is the inductance figure. The lower the inductance figure, the better performing the motor is at speed.
    Hi m_c, again, many thanks for your advice.
    Regards.
    Ray
  1. What size stepper motor do I-need.
    By irving2008 in forum Stepper & Servo Motors
    Last Post: 15-06-2017, 09:18 AM
  2. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  3. Stepper shaft size and pulley bore size problem
  4. What stepper motor size (torque)
    By ZeroCount in forum Stepper & Servo Motors
    Last Post: 09-02-2009, 11:54 PM
