    NikosR's Avatar
    Lives in Χαλάνδρι, Greece. Last Activity: 5 Hours Ago Has been a member for 0-1 years. Has a total post count of 24. Received thanks 1 times, giving thanks to others 23 times.
    Hello.
    Seeing your works (you have made masterpieces) I wanted to upload some of my works from the past.
    There are 2 bases for walnut wood tealights in the style of a chalice, one round and the other hexagonal, varnished.
    I should point out that both the candlestick and the ring are made of a single piece of wood.
    Because I like it a lot and also because of the difficulties I encountered, I have put it as an avatar on the forum.
    I hope you like them.
    NikosR's Avatar
    EDIT: Photo's added to post by Lee.
    "I apologize, but I am unable to upload images due to technical difficulties with the forum. I hope this will be resolved shortly."
ID:	32755   Click image for larger version.
ID:	32756   Click image for larger version.
ID:	32758   Click image for larger version.
ID:	32759   Click image for larger version.
ID:	32757   Click image for larger version.
    @NikosR
    If you would like to email them to me, I can upload them for you and attach to your posts ?
    [email protected] is my email address :)
  4. The Following User Says Thank You to Lee Roberts For This Useful Post:
  5. #4
    Hi Nikos,
    I have attached your photos for your last post for you, your work looks great thanks for sharing. Attached is some MDF items i made last year, the BMW is 6ft long and now hangs in a car show room in Los Angeles. I used a French cleat design for the hanging mechanism.
    P.S The Aston Martin wording is single 3mm MDF letters, I mastered the fit so they could be inserted into the green section once painted seamlessly...
    Translation:
    Έχω επισυνάψει τις φωτογραφίες σου για την τελευταία σου ανάρτηση, η δουλειά σου φαίνεται υπέροχη, ευχαριστώ που την μοιράστηκες. Επισυνάπτω μερικά αντικείμενα από MDF που έφτιαξα πέρυσι. Η BMW έχει μήκος 1,80 μέτρα και τώρα κρέμεται σε μια έκθεση αυτοκινήτων στο Λος Άντζελες. Χρησιμοποίησα ένα γαλλικό σχέδιο με τάπες για τον μηχανισμό ανάρτησης.
    Υ.Γ. Η επιγραφή της Aston Martin είναι μεμονωμένα γράμματα από MDF 3 χιλιοστών, κατάφερα να τα εφαρμόσω τέλεια ώστε να μπορούν να εισαχθούν στο πράσινο τμήμα μόλις βαφτούν άψογα...
Name:	1 -etsy.jpg
ID:	32762   Click image for larger version.
ID:	32763   Click image for larger version.
Name:	2 - etsy.jpg
ID:	32761   Click image for larger version.
ID:	32764   Click image for larger version.
ID:	32765   Click image for larger version.
ID:	32775   Click image for larger version.
Name:	1 - etsy.jpg
ID:	32766   Click image for larger version.
Name:	2 - etsy.jpg
ID:	32767   Click image for larger version.
Name:	3 - etsy.jpg
ID:	32768   Click image for larger version.
Name:	3 - etsy.jpg
Name:	1 - etsy.jpg
ID:	32770   Click image for larger version.
ID:	32771   Click image for larger version.
ID:	32772   Click image for larger version.
Name:	1 - etsy.jpg
ID:	32773   Click image for larger version.
ID:	32774   Click image for larger version.
ID:	32776   Click image for larger version.
Name:	3 - etsy.jpg
ID:	32777   Click image for larger version.
Name:	6 - etsy.jpg
  6. The Following User Says Thank You to Lee Roberts For This Useful Post:
  7. #5
    NikosR's Avatar
    LEE What end mill did you use to cut the 'Aston Martin' letters, and did you use the same one for the pocket on the green surface?
  8. #6
    NikosR's Avatar
    Since I cannot upload photos of my work, I am writing you my website.
    I would like your opinion.
    bit.ly/artwood-nikos
  1. Wooden sunglasses
    By jimkrum in forum Woodworking Project Showcase
    Last Post: 19-02-2026, 04:56 PM
  2. Replies: 14
    Last Post: 31-01-2020, 04:02 PM
  3. My first Wooden Toys
    By davidcha in forum Woodworking Project Showcase
    Last Post: 21-02-2019, 02:38 AM
  4. Wooden CNC
    By Andyshomecrafts in forum Gantry/Router Machines & Building
    Last Post: 10-08-2015, 11:54 PM
  5. wooden joints
    By luke11cnc in forum Woodwork Discussion
    Last Post: 18-10-2012, 11:59 PM
