    Hi, my name is Farzad and I am from Iran.
    I am building a DIY CNC machine for myself, and my goal is to make money with it.
    I designed it in SolidWorks and bought the necessary items (I also made some purchasing mistakes).
    This is my design (it’s mostly inspired by a YouTube channel not an engineer).
    The design is simple and is made from a 250mm × 250mm × 1300mm iron box with 8mm thickness. The material is called ST37. I am going to reinforce it with some + shaped plates and weld them inside the iron box.
    For the linear rail placement, I bought some 35mm ST37 plates that I am going to attach to the main iron box using bolts and epoxy.
    These plates were cut from a very large plate with a torch.
    Stress relieving these parts is costly in heat treatment furnaces.
    Can I use VSR instead of an oven?
    I asked ChatGPT about it, and it suggested that I can grind off the torch-cut areas first and then use VSR on them, because most of the residual stress is concentrated on those cut edges.
Name:	Screenshot 2026-03-31 163440.png
ID:	32823   Click image for larger version.
Name:	Screenshot 2026-03-31 163425.png
ID:	32822   Click image for larger version.
Name:	Screenshot 2026-03-31 163417.png
  1. FOR SALE: Workbench CNC frame
    By fifa in forum Items For Sale
    Last Post: 26-02-2017, 10:12 PM
  2. CNC frame very rigid
    By fifa in forum Machine Frames & Beds
    Last Post: 18-02-2017, 02:34 PM
  3. Design a Steel Machine - Stress-Analysis - Load?
    By kim in forum Gantry/Router Machines & Building
    Last Post: 10-05-2016, 10:15 PM
  4. Replies: 3
    Last Post: 24-11-2013, 02:36 PM
  5. What frame bed and where to buy?
    By icedfusion in forum Machine Discussion
    Last Post: 13-01-2012, 06:39 PM
