The MCB should never emit smoke or suffer a burnt out coil, no matter what load you present it. That suggests you either had a duff MCB or it was connected up incorrectly. Assuming this is a Type B (or Type C) breaker, you shouldn't need anything like a 20A or 32A rating just for a 2-3kW VFD.
If the inrush limiter / soft start relay is causing the problem upon closing, it suggests an intermittent fault in the VFD.
You mention an EMI filter. I wasn't aware these Huayang VFDs had any filtering. If you have fitted one yourself, that's A Good Thing but it shouldn't in any way cause the behaviour you are seeing.
The Following User Says Thank You to Muzzer For This Useful Post:
Circuit breaker and fuses
By mbridge87 in forum General ElectronicsReplies: 13Last Post: 07-11-2020, 11:44 PM -
What is a decent spindle relay ?
By John11668 in forum General ElectronicsReplies: 14Last Post: 29-08-2020, 09:45 PM -
Solid state relay for ON/OFF VFD
By Edward in forum General ElectronicsReplies: 3Last Post: 07-09-2017, 09:49 PM -
Relay coil burning out
By cropwell in forum General ElectronicsReplies: 13Last Post: 11-10-2015, 07:51 PM -
Relay V Contactor
By GTJim in forum General ElectronicsReplies: 9Last Post: 18-03-2014, 10:10 AM
