    Daz's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 1 Day Ago Has been a member for 1-2 years. Has a total post count of 17. Received thanks 4 times, giving thanks to others 0 times.
    Hi, I have sent you a PM with the details, thanks.
    dh42's Avatar
    Lives in Sorbiers, France. Last Activity: 4 Weeks Ago Has been a member for 0-1 years. Has a total post count of 14. Received thanks 4 times, giving thanks to others 0 times.
    registration done ;)
    David
    Daz, that's very cool! Could you show more of its workings please? Will you publish the design?
    I'd love to know what software you are running to achieve that ! eg, how do you get a 20k spindle to run slow enough to start the threading process of the collets ?
  5. #15
    Daz's Avatar
    Hi JohnHaine, yes, I will share some more details. I have a nice slow-motion video of the impact mechanism in action. I will upload it to YouTube over the weekend.
    Re your second question, I won't be sharing the detailed design, as I am making and selling the modules.
  6. #16
    Daz's Avatar
    Quote Originally Posted by needleworks View Post
    I am running LinuxCNC with a Digital Dream EC300 controller that was originally for March3, but I have converted it to LinuxCNC with Remora firmware. I have 2.2Kw spindle that goes up to 24k RPM. I don't remember exactly the RPM resolution, but it is better than 50RPM around the 1k RPM range I am using it for tool changing. The inverter is Huanyang 220v 2.2kw. With this setup, I can run the spindle backwards and forwards, from I think around 300 RPM (I would have to confirm that) all the way up to 24k RPM. After moving from Mach3 to LinuxCNC, the setup is rock solid. I had lots of problems with Mach3.
  7. #17
    Well I could be interested except I use ER16 on my mill.
  8. #18
    Daz's Avatar
    Quote Originally Posted by JohnHaine View Post
    It is very straightforward to modify the ATC module for ER16. Just a simple change to one part, and I would be happy to do it.
    The main challenge will be around the torque your spindle can generate. This is mostly a problem for the unlocking step where the spindle needs to overcome the module's initial resistance from the standstill. In case of my spindle, and with the current module setup, I had to increase the acceleration setting on the VFD to give the spindle a bit more torque, as it was stalling from time to time.
    If you could let me know your spindle model, I can check its specs and let you know if it would work.
  9. #19
    I have a Novamill which uses a DC commutator motor, about 375W. Max speed is 5000 rpm. At the moment I only have manual speed control and no reversing so that would need to be added. The table is also quite small so at the most only room for 2 modules - what size are they?
  10. #20
    Daz's Avatar
    The module external dimensions are: 95mm X 95mm footprint, and 88mm height.
    Checking your spindle, I am afraid you most likely won't have enough torque to operate it. I might consider making a lower torque version in the future, but I will need to modify some internals.
  1. Which laser module?
    By grantx in forum Laser Machines & Building
    Last Post: 12-07-2021, 12:22 PM
  2. FOR SALE: CS-Lab IPA with MPG Module / Handwheel etc - £450.
    By Chaz in forum Items For Sale
    Last Post: 13-12-2019, 11:13 AM
  3. WANTED: stepper driver module
    By tinshak in forum Items Wanted
    Last Post: 16-01-2013, 09:31 AM
  4. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  5. ER20 Collets
    By audioandy in forum Tool & Tooling Technology
    Last Post: 05-08-2009, 10:15 PM
