Thread: ATC module for ER20 spindles
25-04-2026 #21
I have done some more digging and since it is a DC motor, you will have completely different torque curve, with some significant torque available from the start. Theoretically many times higher to what I can get on my 2.2kw spindle at very low RPM, assuming your spindle DC power supply can handle it, it might actually work!
You would need to sort out the manual speed control and the reverse operation, but other than that, it should work.Last edited by Daz; 25-04-2026 at 12:53 PM.
27-04-2026 #22
Thanks for the extra information Daz. If the motor could generate the torque it would need a very different controller, the current one is KBE thermistor type. Something that would generate stall current at low volts would be needed, and anyway as it's a PM motor it might be field limited. Also the height would severely restrict me and my table is only 125mm wide! Shame it's a very nice concept.
27-04-2026 #23
That's as cool as a Hippy Penguin's Jesus Sandals!
27-04-2026 #24
The whole point of an Impact Driver Mechanism is that it isn't reliant on motor torque, it releases the drive in response to pre-settable torque demand, allowing the spindle to accelerate, it then uses spindle system angular momentum against a braking mass to apply the required torque, repeatedly.
The Following User Says Thank You to magicniner For This Useful Post:
27-04-2026 #25
Very cool!
Cant wait to see your first cassette of tooling in play and in production
Here is my first job using the ATC modules. The cover needs some improvements to keep the collets clean.
https://youtu.be/FH3Ue6h8MHE?si=oE4Sxmk5fvD7b8i3
The Following User Says Thank You to Daz For This Useful Post:
27-04-2026 #27
That is Totally Ace!
27-04-2026 #28
28-04-2026 #29
It is the same for tightening and loosening. The operating principle doesn't change. The average torque required to spin the module is low, but the impact torque resulting from the hammer hitting the anvil is high. The impact happens two times every full revolution. The impact torque depends mostly on the spindle RPM.
The main difference between tightening and loosening is that for loosening, the spindle needs to overcome the initial module resistance from the standstill. The resistance comes from the need to overcome the hammer return sprint in order to depres the hammer. Once the hammer is depressed, the anvil (top of the module) can slide over it and make the rotation.
28-04-2026 #30
Aha! Right, I didn't spot that in the video.
Which laser module?
By grantx in forum Laser Machines & BuildingReplies: 8Last Post: 12-07-2021, 12:22 PM -
FOR SALE: CS-Lab IPA with MPG Module / Handwheel etc - £450.
By Chaz in forum Items For SaleReplies: 0Last Post: 13-12-2019, 11:13 AM -
WANTED: stepper driver module
By tinshak in forum Items WantedReplies: 0Last Post: 16-01-2013, 09:31 AM -
FOR SALE: ER20 DIY Spindle Parts
By Mad Professor in forum Items For SaleReplies: 1Last Post: 03-11-2012, 06:51 PM -
ER20 Collets
By audioandy in forum Tool & Tooling TechnologyReplies: 6Last Post: 05-08-2009, 10:15 PM
