    PLAHI's Avatar
    Lives in Burgas, Bulgaria. Last Activity: 3 Weeks Ago Has been a member for 1-2 years. Has a total post count of 5.
    Greetings all,
    I bought this hobby CNC: Luynee 3018 ULTRA : https://www.lunyeecnc.com/products/3...graving-dreams
    I assembled the machine accroding to the included instructions + videos I checked.
    Installed UGS and followed the instructions in this video to do my very first CNC cut: https://www.youtube.com/watch?v=mUO6d7MaeCA
    I did a couple of tries and the machine moves and cuts alright, but what I noticed is my controls are not right.
    When I press the "X-" (left) on the jog controller it goes right, same for the X+ (right) it goes left. Same for Y+/-. Z is OK.
    How do I fix that? I can see in that video, that the person presses left and it goes left, not the other way around.
    This is my machine:
Name:	Luynee 3018 ULTRA.jpg
    Are you still having trouble with your 3018?
    PLAHI's Avatar
    Thank you for checking this out. I managed to flip the controls and it looks OK IMO. I will give it a test today and see if it really is right. I've only done a few test cuts as you can see from the picture. Baby steps... :)
    Yes on mine the up and down seemed to go opposite ways but it was actually doing the right thing. Yes I’m at the same stage as you. Easy has a free month and they have loads of patterns you can use to try out your tooling and speeds
    PLAHI's Avatar
    I have an entry-level license for Deskrpoto, so that's my CAM software. For G-code I am using UGS. I fixed the directions, but the image is flipped and instead of down left as a zero point, machine starts on the uper left corner an does the image upside down if I am facing it. Also, zero point on the suface doesn't work for me. I need to figure these parameters out.
    I know what you mean it’s awkward trying to figure it out by yourself. What helped me learn a little bit was I found a software called easel. You don’t have to download and software it’s just on there homepage. I used there free patterns to try out tooling and speeds. And with that your zero point is always the bottom left corner. When you see a big cnc cutting through something in one pass you think that’s how it will be but on my 3018 muck more that 1mm at a time and it barely handles it but it’s good to learn with
  7. The Following User Says Thank You to danwhite For This Useful Post:
  8. #7
    Keithw's Avatar
    Lives in Cladova, Romania. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 6. Received thanks 2 times, giving thanks to others 0 times.
    If your controller is using GRBL, then there are settings in GRBL to reverse the directions of travel - its simply a question of typing a value into the settings - There is a lot of information online how to do this. Try this: https://github-wiki-see.page/m/gnea/...-Configuration.
    Note you can set many parameters in GRBL - taake care, ,and check what you are doing.
    Keithw
  9. The Following User Says Thank You to Keithw For This Useful Post:
  10. #8
    PLAHI's Avatar
    Yes it is using GRBL, thank you for the link, but I don't think that's the problem. The machine jogs correctly with $3=5. I came to the conclusion it's my CAM software that uses a different coordinate system. I need to correct the settings there. Machine is fine in my humble opinion.
  1. Drives and Controls exhibition 2018
    By murrayg in forum Manufacturer News
    Last Post: 23-03-2018, 05:56 PM
  2. Controls Cabinet size
    By driftspin in forum Control Hardware & Systems
    Last Post: 23-11-2017, 09:34 PM
  3. SH-350 Mirror alignment
    By Wolfster in forum Laser Machines & Building
    Last Post: 30-03-2016, 03:47 PM
  4. FOR SALE: XYZ PRO 3000 with Prototrak MX2 controls
    By FarrerDesign in forum Items For Sale
    Last Post: 17-06-2013, 11:47 AM
  5. DRives and Controls 2012
    By georgetheforge in forum General Electronics
    Last Post: 02-04-2012, 02:51 PM
