Thread: Milling deep into 6062 T6
21-12-2024 #1
Using my Storebro Combi-mill, (top spindle rpm 2500) - 1980s cnc mill
Just looking forward into situations I'm bound to find myself in....
For contour passes, I use 3 flute 10mm dia endmills (25mm usable cutting edge) full doc, 3mm stepover for roughing down, then to 0.2 on finishing passes. The finish has been very good. I could prob go double the stepover but haven't had the machine long enough to test it properly.
using 2D contour passes in fusion, I would like to know if its best to use a large dia endmill to rough the contour passes down. I wondering if I can get away with a 20mm dia ( 50mm long flute ) 35mm doc then go in with a 10mm dia for finishing passes.Last edited by dudz; 21-12-2024 at 08:25 AM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
There are currently 41 users browsing this thread. (0 members and 41 guests)
NEW MEMBER: Jumping in at the deep end
By TimB in forum New Member IntroductionsReplies: 1Last Post: 01-04-2023, 11:37 PM -
Deep Slot Milling in Aluminium - Optimum Cutter Diameter
By guy_ in forum Metalwork DiscussionReplies: 8Last Post: 03-04-2021, 12:09 PM -
Outer cut cutting too deep
By scapaflyer in forum Rails, Guideways & BearingsReplies: 1Last Post: 04-04-2018, 07:42 AM -
4.3 mm holes, 20 mm deep
By Chaz in forum Metalwork DiscussionReplies: 26Last Post: 08-08-2017, 10:46 PM -
How deep can i cut MDF?
By MrWiz73 in forum Machine DiscussionReplies: 6Last Post: 24-08-2011, 10:38 PM
