Thread: Optimum BF46
2 Weeks Ago #1
Hello,
After a lot of thinking about how much I actually use it, I’ve decided to sell my CNC milling machine. I am keeping the wall-mounted control box and the servo motors to upgrade another machine, so this is up for grabs as a bare mechanical roller.
The machine is an Optimum BF46 converted to CNC by Mobasi in Germany. It’s fitted with a pneumatic powered drawbar and a one-shot oiler system, and I’ll include the custom splash guard I made for it (though it’s easily unbolted if you don't want it).
While the servo motors will be harvested, I am leaving all the custom machined belt reduction housings on the machine. This means you just need to bolt on your own motors and hook up a controller to get it cutting. The original factory head-mounted speed/direction box is still intact too, so you can run the spindle manually right away.
Because everything is still fully wired up right now, you are welcome to come and see it moving under power to verify the screws and ways are healthy before buying. Once you are happy, it takes me minutes to unbolt the servos.
Price is £1,250. The machine is located near Cambridge. I no longer have any heavy lifting gear or an engine cranes, so the buyer will need to handle 100% of the extraction, lifting, and transport (it's a heavy beast at around 480kg and sits in a fairly tight corner, so bring skates and a crane).
Drop me a PM if you're interested or want to arrange a viewing.
Google photo links
https://photos.app.goo.gl/NttYcGqaKyJT2yzA7
https://photos.app.goo.gl/AZBPoiuffMxdkbV28
https://photos.app.goo.gl/CdDWpnin9LMGNEpDA
Help for MOTOR 2.2 Kw and control board optimum BF46 milling machine
By BILLYBOUM in forum Optimum Milling MachinesReplies: 30Last Post: 07-02-2023, 05:02 PM -
OPTIMUM Optimill VMCs?
By JOGARA in forum Optimum Milling MachinesReplies: 12Last Post: 09-04-2018, 08:28 PM -
pulse generator for M542 to use on a optimum BF46 Vario
By gnalbant in forum Optimum Milling MachinesReplies: 2Last Post: 03-07-2016, 11:50 AM -
CONVERSION: Optimum BF20L Conversion
By Rikk in forum Conversion Build LogsReplies: 0Last Post: 17-07-2011, 06:00 PM -
optimum diameter???
By m.marino in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 02-04-2010, 12:44 AM
