Thread: frequency converter
2 Hours Ago #1
I have an XSY AT2 frequency converter that is supposed to drive a 500-watt drill column.
Drill column, TBD 500/2005
230 V, 50 Hz, 500 watts, 1440 rpm.
How should I configure this on the frequency converter? The drill column only runs at max. frequency 50 Hz.
1 Hour Ago #2
From what I can see the drill already has 12 speeds set by the belt and pulleys. Though the inverter you have has single phase output which is rare the type of motor on the drill, a single-phase induction motor, will probably not give very good performance over a wider range of speeds. I suggest that you ignore the inverter and just run the drill from the mains, adjusting the speed as necessary by changing the belt position on the pulleys. If you must try the inverter consult the manufacturer's instructions.
AXYZ 4010 - USB to RS485 converter drivers
By boatmanbob in forum AXYZ RoutersReplies: 7Last Post: 25-05-2023, 10:07 PM -
Static converter to power a cnc Lathe???
By Ross77 in forum General ElectronicsReplies: 6Last Post: 28-02-2018, 04:33 PM -
Step/direction to analogue converter
By Agathon in forum Control Hardware & SystemsReplies: 3Last Post: 10-08-2017, 08:58 AM -
Struggling with USB to RS485 USB-485 Converter
By kingcreaky in forum Computer HardwareReplies: 0Last Post: 25-08-2013, 08:04 PM -
FOR SALE: AXYZ USB to RS-485 optically isolated converter for sale £260 ono
By RickyThunders in forum Items For SaleReplies: 0Last Post: 18-07-2011, 11:30 PM
