Thread: Work scrap bin router build
11-01-2010 #12
Thanks for the suggestions, I had considered using counter holes in box section but theres an awfull lot of holes, and I want to keep it simple and as quick as possible to build.
I did run some stress tests when I went for the channel, cant remember the results but it didnt deflect to much, I've no idea what sort of forces are involved, I just put a force of 500N in various directions at the tip of the router, I will re run them and post the results.
If the channel twists to much I have thought about closing the open end with some folded ally channel as a work around.
Thanks for the link and suggestion to the cable anti-racking system, I like the look of that, it appears straightforward to do and could be done afterwards if I get problems so I think I'll stick with the single center ballscrew and use something like this if it becomes a problem.
Vic
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
Recycle electronics or scrap?
By gavztheouch in forum General ElectronicsReplies: 2Last Post: 05-02-2014, 04:16 PM -
eBay: Optical PCB drill - save it from scrap someone!
By bikepete in forum Items On eBay UKReplies: 1Last Post: 14-11-2013, 11:42 PM -
BUILD LOG: Scrap Heap Challenge
By TrickyCNC in forum DIY Router Build LogsReplies: 38Last Post: 16-09-2012, 07:52 AM
