Thread: Work scrap bin router build
I see Vic, hadn't looked that closely. How thick is your steel angle and are you planning to prepare the edge in any way? The side load will translate into a vertical and horizontal force due to the shape of the vbearing. If they are rated for 1700N axially then I would have thought that was fine - I suspect the bearings would force the rails towards each other (or the studs apart) and pop-off the rails long before the bearing gave up!
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
Recycle electronics or scrap?
By gavztheouch in forum General ElectronicsReplies: 2Last Post: 05-02-2014, 04:16 PM -
eBay: Optical PCB drill - save it from scrap someone!
By bikepete in forum Items On eBay UKReplies: 1Last Post: 14-11-2013, 11:42 PM -
BUILD LOG: Scrap Heap Challenge
By TrickyCNC in forum DIY Router Build LogsReplies: 38Last Post: 16-09-2012, 07:52 AM
