Thread: Work scrap bin router build
15-01-2010 #31
It may not be much use but Pacific Bearings have a 'square' bearing using hi tech plastic as the bearing surfaces, each side can be adjusted for clearance .. but I think these may have to run on steel box section ...
Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
15-01-2010 #32No probs with the drawing, probably took me less time than trying to explain in words.Thanks for taking the time to do the drawing, the closing plate idea was going to be my strengthening measure if the channel flexed to much. Using box section as a rail but rotated had occured to me, but I was put off by the radious on the corner of steel box section, Ally has a nice square corner but wouldnt last long with the bearing running on it, I'll try running a bearing along the edge of some steel box and see how the V matches the radius.
Well at least you should have have enough options now.......looking forward to seeing some pic's
Not sure I would bother personally, looks like theres alot of surface contact so high friction and being fully enclosed means the rail cant be supported. I would also guess that the rail would have to be solid as box sections often have slightly concave faces.It may not be much use but Pacific Bearings have a 'square' bearing using hi tech plastic as the bearing surfaces, each side can be adjusted for clearance .. but I think these may have to run on steel box section ...
Still i'm sure someone will prove me wrong :heehee:
17-01-2010 #33
Still pondering at the moment
Just out of interest I've attached the model in DWF format, you'll need Autodesk design review to view it, tiz free
http://usa.autodesk.com/adsk/servlet...&siteID=123112
Still got some fettling to do
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
Recycle electronics or scrap?
By gavztheouch in forum General ElectronicsReplies: 2Last Post: 05-02-2014, 04:16 PM -
eBay: Optical PCB drill - save it from scrap someone!
By bikepete in forum Items On eBay UKReplies: 1Last Post: 14-11-2013, 11:42 PM -
BUILD LOG: Scrap Heap Challenge
By TrickyCNC in forum DIY Router Build LogsReplies: 38Last Post: 16-09-2012, 07:52 AM
