Thread: Timing belts for motors
Thanks Irving for your comments didn't think of the aligning help timming belts could offer, I will give it some thought as to direct drive or timing belts.
cheers
12-01-2010 #2
For milling I use a 36:45 XL belt reduction. Larger pulleys cut less slack and XL pulleys are cheap from RS.
This converts a common or garden 5mm pitch screw to the slightly less usual 4mm pitch at the motor, allows NEMA34 motors without overhanging the mill bed and makes the maths easy...
400 steps/rev on a 4mm (pretend) screw is 100 steps/mm, 10 microns
Switch it 800 steps/rev and you get 5 microns which is about the best you can hope for without spending a lorra lorra money on iron :whistling:
Switch it to 1600 steps/rev, if you can sustain the pulse train for a G0. Tell the hoy poloy that it "resolves" 2.5 microns, tell everyone else that it makes it quieter :heehee:
FOR SALE: Timing belts HTD 336 3M
By viz in forum Items For SaleReplies: 1Last Post: 07-03-2013, 08:22 AM -
Timing Belts
By Ricardoco in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 30-07-2012, 10:54 PM -
Found Timing Belts
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-07-2010, 07:36 PM -
Open Ended Timing Belts
By psiron in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 11-06-2010, 10:55 PM -
Source for XL timing belts and pulleys
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-08-2009, 01:21 PM
