  1. in theory you can slave two drivers off the same step/direction/enable signals. The drivers should be identical as should the motors to ensure the two sides behave similarly.. Personally if you have the System4 I'd use the onboard X+A option and if you want a 4th axis later get a standalone single channel driver...
    so how dose a standalone driver interface with the PC then?
  3. via the breakout board... assuming there are some spare pins, else a second parallel port card. A PC has 3 parallel ports defined in hardware, but usually only one fitted. You can buy a second card for about £15-£20, plus a cheap breakout board...
  1. system4 and mach3
    By cncroutman in forum Artsoft Mach (3 & 4)
    Last Post: 31-08-2010, 07:32 PM
  2. ports and pins for system4
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 18-01-2010, 06:37 PM
  3. wiring up my motors
    By Dan Brown in forum General Electronics
    Last Post: 06-01-2010, 12:02 AM
  4. help with motors
    By soyeb in forum Motor Drivers & Controllers
    Last Post: 27-12-2009, 10:23 PM
  5. motors in the UK
    By sensph in forum Stepper & Servo Motors
    Last Post: 28-08-2008, 11:30 PM
