    Hello, i need some help from someone who has set up system4 on mach3
    i've even got the info that comes with the board in front of me, but i must be doing something wrong as the enable light won't come on.
    if anyone can guide me through what ports and pins they used on the 'motor outputs' and 'output signals' on mach3 i'd be really really gratefull
    i still can't work out what i'm doing wronClick image for larger version.
Name:	mach3 outputsignals.JPG
ID:	1478g here, i'm going to post a couple of screenshots of my configuration and maybe one of you will spot something stupid that iClick image for larger version.
Name:	mach3 motor outputs.JPG
ID:	1477'm missing, you can't see it in the screenshot but i've enabled the charge pump option and entered '1'in both port and pin
Name:	sys4 instructions.JPG
    wow what the hell happened there?? those pics were supposed to be at the bottom
  1. Mach3 ports and pin setup to match my control box
    By Sparky in forum Artsoft Mach (3 & 4)
    Last Post: 13-11-2014, 04:00 PM
  2. New Motherboards and LTP1 ports. (You might have one)
    By Mattbatt in forum General Electronics
    Last Post: 05-04-2013, 10:12 AM
  3. system4 and mach3
    By cncroutman in forum Artsoft Mach (3 & 4)
    Last Post: 31-08-2010, 07:32 PM
  4. 2 motors on X with system4
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 19-01-2010, 09:22 PM
  5. Ports and pins help ? mach 3
    By xchipx in forum Artsoft Mach (3 & 4)
    Last Post: 19-04-2009, 12:45 PM
