Thread: drilling brass?
19-01-2010 #2
Is this old brass?
I used to have terrible trouble with brass and it's wonderful tendency to snatch, but not for many years, thought maybe they'd improved the formula and the world had standardised on CZ something or other.
To drill it you mustn't have any slack in the system, it mustn't be able to pull the bit forwards and dig in. That was it's ambition in life.
Lube might help, you could soften it up, possible not a good idea if it's a bearing face. Treat as per copper, apply soap, heat 'til it goes black. Quench or air cool makes no difference, only way to harden brass is to wait a few years.
Edit: Forgot, it does work harden
Um, err, good luck :whistling:Last edited by Robin Hewitt; 19-01-2010 at 02:15 AM.
RFQ: I need apx 100 brass tubes being cut down
By Chance1234 in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-04-2014, 02:05 PM -
Engraving brass
By Philly in forum Machine DiscussionReplies: 3Last Post: 03-08-2013, 10:09 PM -
RFQ: Brass tags
By drumsticksplinter in forum Projects, Jobs & RequestsReplies: 3Last Post: 23-06-2013, 06:17 PM -
3mm sheet brass
By cropwell in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 09:55 AM -
RFQ: CNC brass engraving from an stl file
By Statstastic in forum Projects, Jobs & RequestsReplies: 35Last Post: 04-10-2012, 10:28 PM
