Thread: idea for linear belt drive
Sweet. Thats so simple, unless I'm reading it wrong. Is that in plan with the belts running through the y axis?
19-01-2010 #2
its the same idea that was documented here to avoid racking when usiing one leadscrew offset from centre. The neat idea here is to make it the drive mechanism too... and I've not seen that before! The great thing about this is the pulleys at each end run in the same direction and in sync, so this works as a drive mechanism. 15 or 20mm belts can take some punishment, so it could work well....
The Following User Says Thank You to irving2008 For This Useful Post:
19-01-2010 #3Export as bmp then use Serif PhotoPlus to convert to JPG,how do you change autocad drawings into something everyone can see?
The Following User Says Thank You to BillTodd For This Useful Post:
10-09-2012 #4
10-09-2012 #5
19-01-2010 #6
thanks once again irving.
I use to work on a machine years ago,that worked very similarly but with wire ropes, which pulled a sledge down a passage that feed cattle.
great what you think of when looking for cheaper alternatives than racks or ballscrews:naughty:
do you think that the belts would deflect(bounce) to much on travel over 8 ft?
19-01-2010 #7
thanks ross
my plan is to build router that can take 8x4 sheets so the belts would run full length of table crossing over gantry to other side,both being driven by toothed gear reduced down from stepper motor then the back of the belts would go round idler then down the other side of router. Hope that kind of makes sense:confused:
I wish i could just draw a bit faster and better but am just learning autocad
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
WANTED: wanted drive belt and pulleys
By oadamo in forum Items WantedReplies: 2Last Post: 13-05-2011, 09:00 PM -
any one know where to get a belt drive convertion for x2
By Scott in forum Sieg Milling MachinesReplies: 15Last Post: 27-09-2010, 08:44 PM -
Standard Drive Belt Size ?
By Lee Roberts in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 19-05-2009, 10:56 AM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
