    if only i understood :(
    Hi Dan
    Sorry, The red area is the effective load capabilities based on a 70% reduction for the horizontal and 30% for an upward force (reverse radial). the dotted line is the combined valule for two rails and blocks.
    Hence the total vertical load is 100 + 30 = 130N ect....
  3. dont forget that the rail is acting as a cantilever as well so there will be increased flex in the rail
    Not quite sure what you mean? are you talking about the actual rail support? if so I wouldnt have thought it would deflect much?
  1. WANTED: Supported rail. The bigger the better
    By r0bsk1 in forum Items Wanted
    Last Post: 08-07-2013, 07:50 PM
  2. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  3. Some thoughts on using supported rail
    By Ross77 in forum Rails, Guideways & Bearings
    Last Post: 29-01-2010, 07:13 PM
  4. 16mm supported rail how many linear bearings
    By progomez in forum Rails, Guideways & Bearings
    Last Post: 15-01-2009, 09:39 PM
  5. Supported rail or other?
    By lateAtNight in forum Rails, Guideways & Bearings
    Last Post: 14-11-2008, 02:28 PM
