Thread: +5V TTL Signal
Hi Guys
I`m trying to use the Spindle commands M3 (ON) and M5 (OFF) in Mach3 to generate the TTL Signals to
open/close my micro-dispensing valve. Mach3 is set to use Port 1 Pin 16 and this connects to the s c r e w terminal
of my Xylotex 4 Axis Board.
Now my problem. Without the valve connected in any way I can issue a spindle ON command and measure 3.90 volts
between pin16 and GND on the s c r e w terminal, as soon as I connect this to my valve driver the voltage drops to 1.7v
I`m getting no signs of life on the valve.
How come I`m not measuring 5v with nothing else connected ?
and why is the voltage dropping to 1.7v
Would it be possible to use a 2nd port in Mach3 and maybe send the spindle signal out on the RS232 (COM1 Port)
then at least it would be independant of the Xylotex Board.
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
Encoder Signal to PC
By antsals in forum General ElectronicsReplies: 6Last Post: 26-04-2011, 10:49 AM
