    Ok, so there comes a time in every CNC builders life where he realises that threaded rod was ok for the first few months, but now it needs some proper ball screw.
    So it is with some major reluctance that I blow the cobwebs off my CNC 'kitty' tin & delve inside to find the minimal amount sloshing about.
    Firstly, I'd rather not upgrade my mill's end supports (which are SK16 ... http://tinyurl.com/ygk4stf ...these in turn hold some bearings with an ID of 8mm) ...esle this is gonna get very costly.
    So to my first question, bearing in mind I have simple needs, my X Axis is about 400mm, my Y Axis is about 300mm ...(I'm not touching my Z axis for now) which would be the most suitable ballscrew for integrating into my present CNC mill (would simple trapezoidal type threaded rod be a better option ...if so which pre made nuts to use ....I've turned my back onnthe DIY nut route - life's for living, not making nuts!)
    Next, I have a Sieg Mini Lathe & an ER32 collet chuck/collet set - would it be possible to use this machine the rods ends down to the aformentioned 8mm diameter?
    Many thanks for any input - Hank.
    Kn8's Avatar
    Location unknown. Last Activity: 10-11-2014 Has been a member for 9-10 years. Has a total post count of 58. Received thanks 1 times, giving thanks to others 0 times.
    Hello Hank
    I have two lead screws taken from a cnc measuring machine that was being scraped, and are too small for my requirements. The thread diameter is 11.4mm and the pitch is approximately 12mm, the thread lengths are approximately 880mm and 610mm the nuts are some sort of nylon. The two open ends are machined to 6mm diameter with a 9mm sleeve pushed over them. These are available if you could make use of them.
    Ivan.
ID:	1674Click image for larger version.
ID:	1675Click image for larger version.
ID:	1676Click image for larger version.
ID:	1677Click image for larger version.
    Result!
    I'll PM you!
    I've got some of them, not actually ball screws but they do look interesting
    After you decide to go to ball screws you then realise double nuts are a good idea, then it's sprung double nuts. I even spring the axial bearings together on the Y/Z and hold the X screw in tension. No measurable backlash, not a sausage, or tiny fraction of a sausage even :heehee:
    Not sure what comes after that because I haven't got there yet :naughty:
    A hearty thanks to kn8.....leadscrews duly collected - the longest one of the pair since hacksawed into two bits ...which as luck would have it was exactly the right length to be sufficient for both X & Y planes.
    Ends of each lead screw piece now turned down to be 8mm diameter (yes, mini lathes are up to the job, but it takes a while!)...my somewhat creaky DIY CNC is now in bits & I'm making some DIY mounts so I can incoproprate the leadscrew nuts that came with the leadscrew (nut mounts will be made out of acrylic - don't ask! But they'll be solid as a rock!)
    Got to say...I'm really looking forward to seeing these puppies turn .....3mm pitch (with nice smooth nuts) - luxury after M8 rod!
    Great news, im pleased for you Hank was very kind of you Kn8, i would love to see the pics of the mounts your going to be making in the acrylic Hank. A build log for this conversion would be cool to follow as well ! CHOP CHOP ! :heehee:
    .Me
    Re photos of the mounts - I'm not sure they'd be up to the std required on here! lol
    Basically I've separated those white leadscrew nuts pictured above (there were three small hex head bolts holding them to their mounts) ...my tack here was to source a rectangular piece of 'mount' material deep enough for the leadscrew nuts to insert into (about 30mm deep....and because I didn't have any acrylic that deep, I've glued some sheets together...transparent arylic about 20mm thick & two pieces of blue acrylic sheet about 5mm thick! Very blue peter-esque!) .
    The leadscrew nut 'extended' bit is 20mm diameter so it's just a matter of boring a 20mm hole through the middle of the acrylic & then attaching the the lot to the underside of each plane's table.
    Sounds awful & I'm sure not up to anything other than hobby standards....but have you seen the price of proper nut mounts
    Sounds intresting, the great thing is once your up and running you can always start remaking your own parts as you need to.
    Here is a ballnut mount i designed for my new machine, i understand what your saying on pricing for the pre made mounts.
    Dont forget you have got a high number of people here who are willing to help each other along, if you needed to you could ask for some parts to be made for you.
    .Me
    Yours are good (no, in fact perfect), mine are aesthetically challenged, but functional - and at least they cost nowt (& are more colourful!)
    The good thing about acrylic is it's free if you have a signmaker near you! (check their skip!) ...also it's very flat (a bit brittle though).....
    One lump of 20mm & two pieces of 5mm (I needed 30mm!)
    Whoever would have thought a 20mm wood bit would be so useful on a metalworker lathe!
    20mm bore to take the leadscrew nut that came with the leadscrew (the hole is *meant* to be offset!)...
    And all assembled ready to be mounded under my machines Y plane table...
    I'm not worried about the colour scheme or the lack of 'finesse'...like I say this is a hobby machine & besides they're outta sight anyway!
    My X axis is finished ...and my Y axis is 70% done (I'm not bothering right now with my Z Axis).....wow what a difference it's making to my rapids - amazing!!!
  10. Don't knock them.. does the job, so its a good engineering solution and I'll doubt you'll get close to the tensile strength limits of acrylic.... What did you bond the pieces with?
  1. machining ballscrews
    By T0rnado69 in forum Lead Screws, Nuts & Supports
    Last Post: 13-04-2014, 11:39 PM
  2. WANTED: FK12 fixed ballscrew support
    By r0bsk1 in forum Items Wanted
    Last Post: 29-10-2013, 10:21 PM
  3. Using SBR12 as ballscrew end support
    By Lovre in forum Lead Screws, Nuts & Supports
    Last Post: 13-12-2012, 08:52 PM
  4. Replies: 0
    Last Post: 09-04-2012, 11:20 AM
  5. Ballscrew Support Bearings - Angular or Self Align or ??
    By williamturner1 in forum Lead Screws, Nuts & Supports
    Last Post: 02-10-2010, 02:38 PM
