31-01-2010 #2
Hello Hank
I have two lead screws taken from a cnc measuring machine that was being scraped, and are too small for my requirements. The thread diameter is 11.4mm and the pitch is approximately 12mm, the thread lengths are approximately 880mm and 610mm the nuts are some sort of nylon. The two open ends are machined to 6mm diameter with a 9mm sleeve pushed over them. These are available if you could make use of them.
Ivan.
machining ballscrews
By T0rnado69 in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 13-04-2014, 11:39 PM -
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
Using SBR12 as ballscrew end support
By Lovre in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 13-12-2012, 08:52 PM -
I need some help, Dukitec FK15 support unt - torque of the nut onto the ballscrew
By range3rrr in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 09-04-2012, 11:20 AM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM
