Don't knock them.. does the job, so its a good engineering solution and I'll doubt you'll get close to the tensile strength limits of acrylic.... What did you bond the pieces with?
14-02-2010 #2
They were keyed a litte then bonded with Cyanoacrylate (which sounds a whole lot better than saying superglue) & clamped in a vice to set...when I spoke of acrylic being brittle earlier, I meant to work with - there' no way on earth those mounts will ever snap in situ!!
14-02-2010 #3
machining ballscrews
By T0rnado69 in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 13-04-2014, 11:39 PM -
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
Using SBR12 as ballscrew end support
By Lovre in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 13-12-2012, 08:52 PM -
I need some help, Dukitec FK15 support unt - torque of the nut onto the ballscrew
By range3rrr in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 09-04-2012, 11:20 AM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM
