It's not just the 20 odd minutes, have you costed a sheet of steel lately ? Average full sheet laser costs between £250.000 and £400,000 and working flat out on production they can get thru 1000 gallons of liquid oxygen in 3 - 4 days.
John S -
04-02-2010 #2Rolled steel will bend if you cut one of the rolled faces off (the stress in the remaining face will no longer be balanced out by the missing side) Mr McSpank would be milling off the edge only so, no serious bend problem.Wouldn't it bend like a banana as soon as he milled one cold rolled side off
I wasn't suggesting "pissing about" making a 100 off on a mill. Hank only wants a couple to prototype his geetah pick-upI'm guessing 35 pence each to get laser cut, would you piss about making one of these for 35 pence ?
04-02-2010 #3
04-02-2010 #4
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
So did I, but I've been following Hank's progress closely and realised he's not quite ready for mass production yet !
