Thread: Gecko G540 - local source
06-02-2010 #11
Just got my G540 from the US for just under £200 , have to see if ive got to pay tax on that yet. Seams an easy solution with its compact size , yet to see if its easy to setup.
L8r
06-02-2010 #12
06-02-2010 #13
Shouldnt be a problem to find motors to match. Gary has a good selection on his site here.
07-02-2010 #14
Mate did a previous search for me, with the Gecko driver the steppers are limited to 3.5A .. interested to see what will suit the gecko
(by the way i'm the newbie messenger)
07-02-2010 #15
You can run steppers below their rated phase current, you just derate the torque by the ratio of the currents. So a 4.2Abipolar stepper rated at 1.8Nm will, on a 3.5A drive, give 1.05Nm RMS instead of 1.27Nm RMS
07-02-2010 #16
07-02-2010 #17
Im replacing my Hobby CNC board with the Gecko mainly because the Zaxis on my mini mill needs more torque. Ive got SY60STH86-3008 Nema 23 stepper motors from Zap on my machine and with the 3.5amp in parallel with 3.3k 5% resistors i should have 2.5nm (or 83% of there ) holding torque ( once i figure how to wire them up lol ). Not much of an increase over the Hobby board at 2.15nm but im hopeing just enough to stop it from stalling. If not then il replace the Z axis motor once i find one that matches the amps , which as you say Compfanon finding motors to match to get the most torque in the Uk is not proving easy. If i dont pay tax then i still think it will be a good buy .... but ive got the feeling il be getting a bill soon , the goverment needs more of my cash.
07-02-2010 #18
Heres hoping the bill gets lost in the system somewhere. The thought of "additional" charges put me off. My plan is to get (3) of the same motors from Zapp and drive with PM752's, all housed in a nice tower case perhaps along with the control pc.
My guru is helping me sort out appropriate power supply.
Good luck with your project.
14-02-2010 #19
15-02-2010 #20
one thing you need to remember is it is not the holding torque you need but the torque at a given speed.
In most cases the holding torque is totally irrelevant.
Also if you under rate the current this will only really effect the torque at the lower speed range, and will have little effect at the higher speeds as this will be lower than the torque you would get at lower current.
Dont forget the lower the current means the higher the inductance and that means you need more volts to force the current through the copper. So spending more money for a 3.5A motor will in most cases give you less performance than using a 4.2A motor and running at 3.5A.
Without the volts you are choking the driver and you will not get a good performance.
People always forget about volts, and with a stepper system it is very important.Visit Us: www.automationshop.co.uk
FOR SALE: Gecko G540 Controller & Accessories
By jeboa in forum Items For SaleReplies: 3Last Post: 21-09-2013, 09:45 AM -
eBay: New Gecko G540 Controller (Rev 8 With Arctic Silver Mounted Heatsink) $1 No Res 3 Day
By Storm2313 in forum Items On eBay UKReplies: 4Last Post: 08-05-2013, 11:31 AM -
GECKO GUYS ! G540 / G250 Users what steppers do you recommend from UK suppliers
By koogar in forum Stepper & Servo MotorsReplies: 6Last Post: 29-06-2011, 03:38 PM -
By koogar in forum Stepper & Servo MotorsReplies: 0Last Post: 23-06-2011, 02:03 PM -
Gecko G540
By Sparks in forum Motor Drivers & ControllersReplies: 14Last Post: 29-11-2010, 04:52 PM
