    I need to make some bass ports for a small speaker - 400 of them!
    I was going to use PVC pipe which is easy to form when heated in an oil bath. However It takes a lot of time.
    Each speaker has 2x 20mm OD ports and if I could get 28mm OD pipe (1mm wall thickness) I would only need one per speaker. PVC pipe seems to go up from 25mm to 32mm, so no help. However copper pipe is 28mm with 1mm wall.
    Do you think I would be able to form it in the shape shown? How? I've seen a metal ram used for more basic expansion. I am thinking the end flare might be too extreme and crack the pipe. The edge of the lip needs to end up at 90 degrees to the pipe length. Any tips?
ID:	15910   Click image for larger version.
  1. Replies: 0
    Last Post: 24-03-2015, 05:04 PM
  2. RFQ: Machine Design and build for PVC pipe
    By D-man in forum Projects, Jobs & Requests
    Last Post: 20-07-2014, 06:10 PM
  3. cutting and engraving sheet alu and copper with cnc router
    By chris in forum Metalwork Discussion
    Last Post: 21-02-2014, 10:55 AM
  4. expanding foam and steel frame
    By Gytis in forum Metalwork Discussion
    Last Post: 18-08-2013, 10:35 AM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
