16-02-2010 #12
Hi Robin,
I'll try the bearings and let you know.
By "inters" I meant two intermediate pulleys, so four in all. Every other Warco Major I have seen, had one intermediate pulley.
From my perspective, it is just another component to add errors to the setup. I guess I could dump one pulley, and get longer belts.
Thanks for the short list, by overhangs, do you mean the machine itself, or mounting of the workpiece?
The right tool for the job.
The right lube
The right feed rate and rpm
I did not notice the difference in your mill until I read your message. It does seem then that the column is the problem, that you can remove it from the equation by lowering the head to the support, it's case solved then.
I have had a few ideas for improving things here, one was to mill square a large cast-iron wieght, and then mount the column support onto it, with the column through it.
I have enquired about a solid steel column, which could be cut with a groove to locate it radially, a la' Arborga mills.
A square column is the ideal I guess, but not a good use of time for me (silk purse and sow's ear etc. ) better to buy another machine.
So maybe i will have to be satified with small cuts.....?
A Fursty Ferret is calling me, so time to go.
Many thanks
Mark
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Warco Major CNC build log
By Robin Hewitt in forum Conversion Build LogsReplies: 100Last Post: 10-12-2010, 03:14 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
