18-10-2012 #15
The only thing I can think of for a work around on this is at the end of your G code when your tool maybe goes to X0 Y0 Z30 (example only) you can change the code so your axis finish on the positive side of your home switch so X50 Y50 Z30 (example only) then when you reference you should be ok.
Other than that move your home switch to the Neg side of movement on your X and Y axis.
hope this helps
Andy
G540, homing switches and mach3
By marbles in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 02-06-2018, 02:55 PM -
Limit switches and Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 06-03-2013, 10:51 AM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM -
A simple query about homing switches & milling practise
By HankMcSpank in forum General DiscussionReplies: 5Last Post: 13-06-2009, 11:56 PM
