    Quote Originally Posted by BillTodd View Post
    The scale is (I think) just a PCB in (another guess) a sinusoidal shape. A source of the scale 'tape' would be VERY useful; It could be just stuck to the side of a mill table, for instance, and be read by a close fitting head (no bulky scale of PITA fixings).
    Is it possible they fit them to stainless because it is non-magnetic?
    I remember, back in my days as digitizer tech support, the manufacturer accidentally printed a menu overlay for a capacitive tablet using conductive ink. Oops-Splatt :heehee:
    I got the impression that the technology wasn't friendly if messed with.
    Did you try insulating the scale then sticking a cap to ground to de-jitter it? They don't seem to bother much with decoupling.
    Robin
  2. Quote Originally Posted by Robin Hewitt View Post
    Robin
    There's about 1uF of inbuilt capacitor. The scale is powered all the time its just the display thats turned on and off, at least on these ones, so they read the same when you turn them on as when turned off... as long as you dont move them. I've seen a number of articles that suggest putting 100nF + 10uF when powered remotely and no battery in the compartment. I like Bill's idea of a local reader pcb and localising the power arrangement, that will get rid of many glitches. I've sketched a design using a small number of SMT parts that can be fitted to the existing reader PCB instead of the display case. I think a small bit of ali milled to suit will act as a suitable casing.
    The existing case is definitely built down to a price. It took several attempts to get the display to work again after I dismantled it because the positioning of, and pressure on, the zebra connector seems to be critical. and the screw holes are marginal at best... in fact the 4 retaining screws for the PCB have all but one pulled through the pcb so i flowed a little solder in the holes to tighten them up.
    I am debating whether to grind the calipery bits off or try to use them as a mount...
    oh the other thought I had was making the PIC do calibration to improve accuracy over the long runs... some form of look up table of offsets per cm
    and another thought: what about compensation for temperature? does the PCB expand enough to warrant it?
  3. the other thought I had was making the PIC do calibration to improve accuracy over the long runs... some form of look up table of offsets per cm
    Certainly do-able. Of course, it does require a calibration standard of must higher accuracy than the scales (thinks: I have a magnescale strapped to the side of my lathe that's good to a few microns over its entire length).
    Though frankly, for the RF30 type mill I'm using them on, they're probably good enough as they are.
    If, as you suggest the pcb is a set of disconnected copper fingers then I guess it is compliant enough to flex with the SS carrier.
    They cut easily with a friction saw but watch the temperature,as you don't want the glue to come undone. I drilled mounting holes with a carbide pcb drill.
    Were you thinking of making a stand-alone display device or using a PC?
  4. Quote Originally Posted by BillTodd View Post
    Ditto for my MD30, the 12" claims 0.04mm across the full length, 0.01mm 0 - 100mm. Since nothing I make (to date) is bigger than 100mm....
    I was going to use 15 0.8" led 7-Segment displays and a couple of driver chips and a PIC, the displays are only 50p each and the PCB for it is simple enough. Doesn't warrant the hassle of a PC. Depending on the PIC I might add a USB port so a PC can read them too.
  5. You might be able to save yourself some effort (I hate PCB layout) by using a EPOS display like this with serial input and large VFD
    Or if you fancy tinkering...
    http://cgi.ebay.co.uk/new-2-line-by-...item2c52e20dc2
  6. Hmmmm.... theres an idea...£4.99 isnt going to break the bank...
    No doubt if I made it work somebody'd want to copy it
    <edit>
    Oh Google is a wonderful tool ... These are manufactured for Fujitsu (ICL as was) and are probably a RS232 serial interface (EPSON emulation) with a 12v 10W supply requirement. Shouldnt be too hard to figure it out. Only 9mm character height tho if these were the customer facing ones, 11mm otherwise..
  1. Fixing linear rail - DIY practice
    By CharlesJenkinson in forum Rails, Guideways & Bearings
    Last Post: 10-02-2014, 12:53 PM
  2. NEW MEMBER: Hi from Reading
    By Saracen in forum New Member Introductions
    Last Post: 26-11-2012, 01:50 AM
  3. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  4. FOR SALE: DRO + 4 Scales
    By Rikk in forum Items For Sale
    Last Post: 22-10-2011, 09:41 AM
  5. Mill with digital scales
    By Robin Hewitt in forum Milling Machines, Builds & Conversions
    Last Post: 22-08-2008, 10:21 AM
