  1. This is running off a remote 1.5V supply generated using a 555 and a -ve charge pump
    Can't you use a spare o/p pin on the PIC instead of the 555?
    and a few tens of lines of C code later...
    I s C fast enough to read the clock pulses or are you using in-line assembler ? (ISTR the guy on cnczone couldn't get it to work in C)
    Bill/Robin, I know you guys have both done something along these lines already, how did you force the scales into fast read mode (currently I do this by hand) and, more importantly, how did you know when they got there and weren't in some 'hold' mode?
    If you look at the PIC code I posted on the CNCzone site, you'll see the sequence I used (I don't have it to hand ATM).
    Essentially, I measure the data repeat rate from the scale to determine the current mode then apply pulses to change to the desired mode. The clk/data pulse sequence varies from scale to scale so I also test the data type to determine the type of scale.
    Hold mode is a PITA because i can see no way to test the scale in in that Mode. In the end, I just used a reliable 'get back to normal' sequence then output the fast mode sequence blindly.
    I have a one scale here that requires one extra pulse to get it to fast mode from hold, yet no way to determine the that this is a different type of scale from within the PIC. I will either have to program a special chip just for this scale or change the PIC code so it stores the sequence in EEPROM , that way I can change it from the PC program.
    [edit]
    Here you go:
    Code:
    ;Zero vernier display
    Zero        movf    rxbuff+1,w
            andlw    0xDF
            xorwf    IDbyte,w    ;test correct axis
            btfss    status,z
            return
            call    zeronorm
            btfss    Mode,Fast    ;if it was in fast mode then setfast
            return
            goto    setFast
    ;set zero normal mode
    ZeroNorm    call    measure    ;measure checks the clock to determine fast/slow mode
            btfss    Mode,Fflg
            goto    tstslow
    pdlp        call    PlsData        ;pulse data until slow
            call    measure
            btfsc    Mode,Fflg    ;test slow
            goto    pdlp
            call     PlsClk        ;pulse clk (zero switch)
            return
    ;measure the vernier reading speed (300mS slow,20mS fast)
    measure        bcf    CMCON,CIS    ;switch comp to clk input
            call    synlp        ;wait for clock low >1mS
            bcf    Mode,Fflg
    ;if clock occurs within ~25mS then Fast flag will be set
            movlw    25
            movwf    vdata        ;borrow vdata as counter
    m2lp        btfsc    CMCON,COUT
            bsf    Mode,Fflg    ;
            decfsz    vdata+3,f
            goto    m2lp
            decfsz    vdata,f
            goto    m2lp
            return
    Tstslow        call     PlsClk        ;pulse clk
            call    measure
            goto    pdlp        ;if fast, pulse data until slow
            return            ;normal zero
  1. Fixing linear rail - DIY practice
    By CharlesJenkinson in forum Rails, Guideways & Bearings
    Last Post: 10-02-2014, 12:53 PM
  2. NEW MEMBER: Hi from Reading
    By Saracen in forum New Member Introductions
    Last Post: 26-11-2012, 01:50 AM
  3. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  4. FOR SALE: DRO + 4 Scales
    By Rikk in forum Items For Sale
    Last Post: 22-10-2011, 09:41 AM
  5. Mill with digital scales
    By Robin Hewitt in forum Milling Machines, Builds & Conversions
    Last Post: 22-08-2008, 10:21 AM
