Let’s not forget Motion Control Products, Marchant Dice and of course my company AXISCNC.
Quality, the ball screws coming out of MCP are a mixture of Chinese and Taiwanese products, these would also be coming from the same manufacture as the ones from MD.
Do you need traceability, MD offer full material and process traceability?
Ball screws are made in Taiwan and the lower cost ball nuts you see popping up on sites like eBay are coming out of China. The quality difference in the Chinese vs. Taiwanese is fairly significant, the Taiwanese being the better product.
Hardness,
Ground ball screws should have a greater depth of hardness through to the core of the screw, when they do the grinding process more heat is generated over a longer period of time and this heat is able to penetrate towards the core of the screw.
Rolled ball screws should be that bit more malleable, this is needed for the rolling process when producing the ball thread on the screw. The screw should then be case hardened; this would normally be done to a shallow depth and as a final machining process.
LeeLee
stepper motor selection for my diy cnc machine
By crossleymarko in forum Stepper & Servo MotorsReplies: 1Last Post: 08-04-2012, 03:19 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
1.5mm ball end mill supplier in the uk
By luke11cnc in forum Marketplace DiscussionReplies: 9Last Post: 21-01-2012, 08:25 PM -
Dilemma with ball screw and motor mounting
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 12-08-2011, 10:58 AM -
WANTED: UNC grub screw supplier?
By m_c in forum Items WantedReplies: 3Last Post: 01-11-2008, 01:51 AM
