Page 1 of 3 123 LastLast
  1. There is web address with few pics of my DIY CNC. http://malamuterun.co.uk/cnc/homemade_cnc_mill.htm
    nice work mate lovin the web site.
    there is no such thing as a stupid question, just stupid answers !!!!
  3. The Following User Says Thank You to h4ppy-chris For This Useful Post:
  4. I use T2.5x6mm Synchroflex timing belts to transfer power from stepper to lead screw.X and Y axes have two motors to rotate the screws. And yesterday the belt snapped, not for the first time I gotta say. So now I'm planning to replace two 2.5mm pitch belts with one 5mm pitch on Y axis but still leaving two motors to steer two lead screws. Of course I'll need to replace timing pulleys and make some tensioners. Stuff ordered,hope it will work.
ID:	3746Click image for larger version.
ID:	3747Click image for larger version.
ID:	3748Click image for larger version.
  5. #4
    Looking good
    Quote Originally Posted by wiatroda View Post
    I use T2.5x6mm Synchroflex timing belts to transfer power from stepper to lead screw...
    I've used XL pitch belts, at least 1/2" wide and have never had any problems. Can also make your own pulleys for them with a bit of care which saves a bit.
    What have you used for the nuts on, I think, the X axis? Is it just a brass/bronze bar tapped with the hole for oil or something more elaborate?
  6. I don't have rotary table to cut the pulleys :( . Money are sometimes an issue so I went for smaller pitch, cheaper belts and pulleys. On all axis I've got M16x2 lead screws. Nuts I've made myself from 32mm dia steel bar. They are 60mm long with a grease nipple re-drilled to fit 4mm nylon tube for oiling. Very simple, good and cheap solution, with no backlash at all.
  7. #6
    you don't need a rotary table to cut the pulleys use your cnc to cut them out of plate ;)
  8. You are right Chris. I've never cut timing pulleys, but some time ago I was messing with robotic arm gripper. All parts I've cut on my CNC from 3mm steel.
ID:	3751Click image for larger version.
  9. #8
    Quote Originally Posted by h4ppy-chris View Post
    That does of course depend on the profile. You'd need a very small cutter to get a decent XL pulley with that method.
  10. Stuff have arrived. I managed to do some drawing . Hope tomorrow I'll find some time to put it together :)
ID:	3755Click image for larger version.
Name:	timing pulleys.jpg
ID:	3754Click image for larger version.
  11. #10
    Is this PM542 stepper driver? What voltage do you use?
  1. BUILD LOG: jon's homemade cnc
    By jonbabbz in forum DIY Router Build Logs
    Last Post: 11-03-2021, 05:13 AM
  2. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  3. Homemade CNC Project Help
    By chaslam07 in forum Gantry/Router Machines & Building
    Last Post: 04-04-2012, 11:53 AM
  4. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
