Thread: RobinCAM v1.0
22-03-2010 #11
Oops! Forgot pockets inside pockets
This means completely re-writing the island waterline detector :whistling:
Brane starting to faid, need beer
23-03-2010 #12
Its coming on Robin, what parameters are going to be setable, depth of cut, tool size etc ?
John
25-03-2010 #13
Everything I can't glean from the .dxf file, but I do my best. Have a movie...
Edit: If it won't play, here's the link http://www.youtube.com/watch?v=Hnaftasy7yo
11-05-2010 #14
Something of a hiatus, now going again
This morning it started puking out G-code, read some in to my cutting software and it looks good
After much agonising about how to define tools inside a drawing file I eventually opted for added text.
T01 is the only tool that removes excess from the block. No T01=no excess removal. So you can go back in and tweak without massive editing of G code.
Still Um'ing and Ah'ing about whether to allow finishing excess in the Z axis when you reach the bottom of the block. I think probably not, total waste of time.
The RCA text line in the pic forces a 2 degree draft angle on anything with the same layer. Will probably add other modifiers to that.
More soon, probably. I can still come horribly unstuck, but looks hopeful. The proof of the pudding will be in the eating :heehee:
11-05-2010 #15
Robin,
Rather than regen the cut, could you just store the vertexes and re-display them? (There must be some PD 3D C++ libraries available on the web somewhere that would do this kind of thing for you)
Bill
11-05-2010 #16
Hi Bill
What's a vertex? :heehee:
There is no cleverness in this program, it simply reads in a dxf, slices through at various levels then projects the slices in to cuts. That was about all my brane could handle.
Robin
