The first pieces cut might, but then the leading edge of the angle grinder disc would start to thin. The metal would then cut with the narrowed edge of the disc, then face on the less worn sides.
This is assuming your pivots are tight. If not tight then you might need to joggle it side to side after cutting to get the burr free face.
You could probably remove any heat bluing chemically if it worried you, or add splash guards so you could cut it wet.
This could be automated fairly easily with cams :naughty:
Robin
09-03-2010 #2
Another option for cutting would be to use a shear (or large bolt croppers) if your going to clean up the ends? cut oversize and grind back to appropriate size
22-03-2010 #3
If the job is not already done.....part them off in your lathe.
Go in 1mm, back out and de burr the edges. Then back in to complete the parting.
FOR SALE: Any one wishing to buy a CNC length stop bench can make me a offer
By suesi34e in forum Items For SaleReplies: 3Last Post: 07-05-2014, 10:20 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
FOR SALE: 2x 2005 C7 Ballscrew 1450mm Length with Ballnuts + FK/FF mounts and motor coupler
By Shinobiwan in forum Items For SaleReplies: 38Last Post: 31-12-2012, 02:42 PM -
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM
