09-03-2010 #10
The reason i suggested what i did was that had to cut down the 30mm and 20mm rails for my build. I did this but putting the rod in the lathe and used an angle grinder to shorten and face off the ends. This worked great so should not see why it would not work in a mill/ vertical drill to do the same on smaller diameter rod. The fact that the abrasive disc would pick off the burs from the edges should prove quite well and if you use a pecking motion then should be no reason why should end up with blueing (gaps btween pecks)? my second idea was to use the very small mini drill cutting discs (they do not last long)
FOR SALE: Any one wishing to buy a CNC length stop bench can make me a offer
By suesi34e in forum Items For SaleReplies: 3Last Post: 07-05-2014, 10:20 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
FOR SALE: 2x 2005 C7 Ballscrew 1450mm Length with Ballnuts + FK/FF mounts and motor coupler
By Shinobiwan in forum Items For SaleReplies: 38Last Post: 31-12-2012, 02:42 PM -
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM
