  1. #14
    Just ran the spindle again and still not happy with it.....
    The problem bearings at the moment are 2 x 16004's - dimensions OD 42mm x ID 30mm x width 8mm
    Decided to change them for some 6004's - dimensions OD 42mm x ID 20mm x width 12mm
    Will need to do a bit of a mod to the housing and make up a new spacer for the spindle but think its worth it as they have a higher load rating than the originals.
    Just rang my bearing man up and he has them in stock, apparantly they are used quite a lot for motorbike wheel bearings and he has plenty on the shelf. Price - £3.50 each for NSK's!
    Where's me van keys.........
  2. The Following User Says Thank You to HiltonSteve For This Useful Post:
  1. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  2. what spindle should i buy for an isel fb2 machine?
    By nobby in forum Machine Discussion
    Last Post: 27-06-2013, 03:38 PM
  3. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 01:05 AM
  4. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 11:54 AM
  5. Router spindle idea
    By HiltonSteve in forum Spindles & Drive Motors
    Last Post: 19-01-2010, 08:59 AM
