Thread: 3M x 2M Plasma table build
25-08-2009 #3
Quick update......
Just a quick video of the Plasma table going through the motions. I still haven't sorted out the torch height controller yet as I bury the tip after about 2" of cut and stuff it up. I have so far burnt out 6 tips and 3 shields trying to get it to work properly. It's an expensive test cut. I will try the test with the plate on a slope to give myself a bit more time to hit the reset button on Mach so i don't bury the tip as quickly and to see if the height controller is following the contours.
I'll post some pics soon.
It's undergone a few design changes since the first one but I think I will settle on this one as it's pretty smooth and I will probably change out the X axis timing belt with a chain like the Y axis just to keep everything the same. You can hear the timing belt riding along the edge of the toothed pulley so it's not tracking really well. A bit of dry lube will fix that though.
Rich.
[ame="http://www.youtube.com/watch?v=vETkf1sqo3M"]YouTube - Plasma Small[/ame]
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
BUILD LOG: 4' x 4' plasma table build in Canada
By 190-v8 in forum DIY Plasma Build LogsReplies: 2Last Post: 02-02-2014, 01:19 AM -
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM
