Thread: 8020 belt driven 3 axis
It has been well documented in lots of places that using a Laptop for CNC control is not a great idea. There is no reason why it shouldn't work superficially, but it is risky if you want consistent decent results [bet someone is successful though]. The main reason is that both the operating system (specifically Windows) and the BIOS of laptops have deeply rooted features for extending the battery life. You can, and should, turm off all the features that suspend or even slow the processor down after periods of inactivity or elapsed time, but there is still the nagging doubt that somewhere deep down in the software, interrupts and latency are being disturbed. The symptoms would be disruption of the real time nature of Mach with missed steps or false readings or worse still, crashes and lock ups.
The situation with EMC and Ubuntu is a little different as this installation has a real time add on to the operating system. This makes it better than the Windows situation but still does not eliminate whatever the manufacturer of the laptop chose for the BIOS.
6m X axis Rack and pinion or belt drive?
By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM -
Belt driven CNC mill - some questions
By Cyclonit in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 30-04-2014, 12:39 AM -
NEW MEMBER: New member with a new 8020 design
By cncgreg in forum New Member IntroductionsReplies: 11Last Post: 04-08-2010, 07:07 PM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM -
8020 Bicycle
By Lee Roberts in forum General DiscussionReplies: 0Last Post: 08-05-2009, 07:03 PM
