19-02-2011 #2
19-02-2011 #3
Take it apart and check it. The worm wheel is just cast iron bolted onto the underside, which i discovered after removing several teeth while machining a bit 1/2" thick steel into a 12" round :-/
Someday, once I've got the mill converted, I'll get it converted into a 4th axis.
18-02-2011 #4
A bit of an update,
re posting pic's here on the build and giving a bit more info on what I am up to. Also hope to be able to load a video as well. Got the system 4 on line and it is really making a bit of difference with the reduced wire runs and being able to condense things a bit. Have made a few widgets for setting edges on projects for clamping and proving useful. I am going to be milling some of the cable guides and safety switches out of acrylic and that is going well in the design phase (will post the .dxf files when I have them done). So all and all things are moving forward. Bought a 4th axis and will post pics here.
Here is the pic's:
Here is a bit of video:
Well take care and hope to have some more cutting to show shortly. Also can I get permission to post .dxf please.
Michael
18-02-2011 #5
Hi Michael,
You should be able to zip them and then upload them. For example . . .
19-02-2011 #6
m_c,
I am in Edinburgh. You are more than welcome to contact me and come over to look at the shop.
Michael
08-06-2011 #7
Well been getting some good cutting going (enough to require maintenance duty on the machine beyond normal clean up after a days work) and looking to do some upgrade work on the Wee Beastie.
Looking for input on the best method for upgrading to Ballscrews and also raising the Z axis while keeping the rigidity up (if not increasing it). I am looking at either Alli' plate or extrusions and would like input there on the Y/Z axis unit (going to raising to 100-125 mm travel to allow the addition of an A-axis to the unit [already have the unit]).
On the Ballscrew front what I am interested in information wise is input on how best to convert the unit I have (a Merchant Dice TR model) to Ballscrews. I have been looking at Zap and a few others and would like in put on the best method for setting up the bearings for the ballscrews and if it would be wise/possible to upgrade to 20mm ballscrew from the 16mm trapezoid screw that is currently there (this is on the X axis, on the Y and Z I plan to upgrade to increase rigidity a bit).
Still cutting and business is improving so things going well. Hope everyone else is having a great day and take care.
Michael
08-06-2011 #8
Just make it as strong as you can. Extrusion is great if you can afford it. Plate is the worst solution in terms of bending for the gantry sides. Aluminum or steel channel or box section will be much stronger with forces parellel to the Y axis for the same mass. Irving posted an excellent spreadsheet about it somewhere...
I would be inclined to increase the distance between the bearings on the X axis. This will of course loose travel but it may be neccarcy to keep it rigid.
You could consider just simply raising the Y/Z axis to fit the A axis and leaving the Z axis with the same travel. That way you will only have the bending of taller gantry sides to worry about. When you don't want to use the A axis drop it down again. The slots in the aluminium extrusion make this easy to do and you could put a block of aluminum on either gantry side at the current height to locate the gantry so you don't have to get it level every time.
The eBay seller linearmotionbearings2008 is much much cheaper than Zap. They will cut the screws to length and machine them. I've ordered a few times from them and not had any problems.
The diameter of the ballscrew required depends on the length, and end fixity. I would put a double row angular contact bearing (or a pair of single row) at one end and a standard deep groove bearing at the other. The best way is to have angular contact bearings at both ends, however the critical speed of a 16mm screw, 400mm long (just guessing the size, correct me if I'm wrong) with the above bearings is around 10,000rpm - so plenty! I'm using a 550mm (ish) 16mm ballscrew on my Z-axis and it happily went at 10,000mm/min - it's limited by the motor torque.
Since the critical speed for a 16mm ballscrew is so high there's not really much point using a 20mm screw. You're not going to exceed the load ratings of the 16mm either. Also if you had a 20mm screw the inertia is much greater (the effect is proportional to the diameter of the screw to the power 4), so your acceleration will suffer. The same is true with changing from 12mm to 16mm screws, however ballscrews are much more efficient than trapezoidal screws so you'll end up fine. Thinking about it it's not really an issue since the screws you have currently are 3mm pitch (I think?), which will have to turn faster than a 5mm pitch ballscrew ... so etc... (I think I've written enough!)Last edited by Jonathan; 08-06-2011 at 12:27 PM.
08-06-2011 #9
Thanks Jonathan,
Definitely some things to think on and thanks for the additional resource.
Michael
DesignCAD 3D MAX v.21 review
By Magic in forum DesignCADReplies: 39Last Post: 28-02-2014, 08:06 AM -
Please review this router gantry idea
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 34Last Post: 09-09-2013, 04:47 PM -
Review our filament for 10% off
By simoni in forum Manufacturer NewsReplies: 3Last Post: 04-08-2013, 11:14 AM -
Review: Design Spark PCB software
By Robin Hewitt in forum General ElectronicsReplies: 4Last Post: 29-05-2013, 10:54 PM -
FOR SALE: 48V Power Supply - The clear-out continues
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 09-02-2011, 02:14 PM
