09-04-2010 #1
hi
in mach 3 if i jog the x axis in the + direction then stop , then jog again in the in the + direction , some times the axis goes the opposite way but the dro is still incrementing in the + direction , anyone any ideas
also does the same when cutting , disconnected the motor from the screw so as there is no load and it still does it
09-04-2010 #2
John
I had this problem with EMC2 and after checking things for the 50,000 time it turned out to be a bad contact on a motor wire. Suggest you loosen the screws on that motor, take them out, re twist or solder the ends and put hem back. Worth a tryIf the nagging gets really bad......Get a bigger shed:naughty:
09-04-2010 #3
thanks 2e0poz
will check wiring , as you say for the 50,000 time tomorrow, it must be a wiring prob but do you think i can find it
thats the great thing about this cnc mallarky .. keeps the mind active
09-04-2010 #4
also check your direction feed.
11-04-2010 #5
hi
found it at last one of the motor wires , going into the terminal block on the driver was under the spade screw instead of between it although to the touch the wire felt solid it wasnt a good electrical connection , wire in right place everything ok now ... for some thing so simple its been a right pain in the arse
11-04-2010 #6
Glad to see you grb the gremlin by the P****** John and now under control
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM -
Wire Connection Diagrams
By Lee Roberts in forum Stepper & Servo MotorsReplies: 14Last Post: 03-01-2013, 06:56 PM -
Electrical whizz needed :)
By don_jarr in forum Motor Drivers & ControllersReplies: 22Last Post: 23-06-2012, 08:10 PM
