15-04-2010 #3
Thanks Irving - a great reply.
Fortunately, my router (a Proxxon BFW 40e), has a range 900rpm-6000rpm, so dropping the RPMs is not an issue.
That said, it's only 250W...which I guess isn't great wrt cutting steel - I guess it'll be a suck & see job ....need to order up a 2 flute cutter & give it a go.
Would it be better to go with an even thinner sized endmill? (say 2mm diameter )....my thinking here is the less steel it has to channel out around the part, the less stress there'll be on everything? But then again, I guess you've then got to start wondering about the physical strength of the endmill at such smaller diameters (ie snapsville)?
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
