Thread: Play in linear bearings
29-04-2010 #4
Dam thats just complicated things. I thought you were talking about the profile rails and carrages. Ignore the comment on adding or changing balls for preload, thats only for the profile rails I think.
Unsupported rails are ok 'ish' for short runs and thats why some use them for the z axis. Not sure for 400mm tho.....is that travel or total length. you mentioned 200x200 at the start.
I dont think that open bearings and supported rail are a problem as long as they are not subject to large side loadings (note there are varying quaility of these bearings and strength of the mounting blocks.)
To make a decision as to the best rails, you need to know what style of machine, what you plan to cut and what tolerance you require.
If its a fixed gantry cutting mdf to 0.5mm tolerance then you would probably get away with unsupported rails. mention Ali and forget it, there have been quite a few builds that have started with unsupported and then changed later at extra cost.
I seem to remember doing a cost comparison vs performance and the profile rails didnt come out much more expensive because you can get away with one one block and a much smaller size rail. and looking at the whole picture the lower mass also helps with smaller ballscrews, motors and controllers
DIY Linear Bearings
By CraftyGeek in forum Rails, Guideways & BearingsReplies: 17Last Post: 05-08-2013, 11:08 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
FOR SALE: 25mm Linear Slide bearings
By D-man in forum Items For SaleReplies: 4Last Post: 28-11-2010, 05:14 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
Anybody used these linear bearings before?
By pjl83 in forum Rails, Guideways & BearingsReplies: 9Last Post: 08-06-2010, 12:42 PM
