04-05-2010 #6
Be careful as high accuracy will come with a high price tag, what are you making that needs to be manufactured to that degree of accuracy???
Not so sure about your cooling/heating idea for the aluminium frame, aluminium will expand at twice the amount of steel but for a machine as small as you are describing then not so sure it would be necessary.
For instance, a 100mm length of steel will increase or decrease in length by 0.00126mm for every degree C of temperature change so a temperature change of say 20 degrees C will change the length by 0.0252mm, aluminium will be approx twice this with a change of 0.048mm.
Buy yourself a good heater for the winter and open the doors in the summer then you should not see much difference!
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
WANTED: Wanted - small bench cnc mill
By camhguh in forum Items WantedReplies: 2Last Post: 25-01-2012, 11:22 AM -
1st CNC Mill for small machine shop
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-09-2011, 10:47 PM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Best software set for a small cnc mill ?
By NICKMODELMAKER in forum Computer SoftwareReplies: 3Last Post: 12-06-2010, 11:20 PM
