05-05-2010 #9
Hi Robin,
1 thou , 0.001 inch, 25 microns for the youngsters, is quite easy over a small distance with a well adjusted machine, but gets progressively harder over long distances. I have aimed at this over the 200mm by 200mm by 100 mm range, quite tight enough - and even if I get close it should be good.
I have rejected converting an old milling machine on a simple basis, space available is of the order of 1000mm by 600mm including access so say 600mm by 600mm.
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
WANTED: Wanted - small bench cnc mill
By camhguh in forum Items WantedReplies: 2Last Post: 25-01-2012, 11:22 AM -
1st CNC Mill for small machine shop
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-09-2011, 10:47 PM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Best software set for a small cnc mill ?
By NICKMODELMAKER in forum Computer SoftwareReplies: 3Last Post: 12-06-2010, 11:20 PM
