  1. Quote Originally Posted by leadinglights View Post
    .... The same mass of aluminium should be more rigid than steel...
    about 3 times more rigid... but also 1.7x linear length, i.e a beam 5cm x 5cm steel will need to be 8.5cm x 8.5cm in aluminium for the same mass, or 6.5cm x 6.5cm for the same rigidity, but because it is less dense it will more easily transmit vibrations from motor to workpiece partly destroying the benefits...
    Hopefully easier to address than many of the other potential problems. Modern motors, whether stepper, servo or BLDC tend to be smooth and powerful and compliance for damping in the mountings of less consequence than in ballscrews, guides etc.
    Mike
  1. BUILD LOG: Design stage of 4030(ish) for wood and plastic
    By andy586 in forum DIY Router Build Logs
    Last Post: 14-11-2013, 10:07 PM
  2. WANTED: Wanted - small bench cnc mill
    By camhguh in forum Items Wanted
    Last Post: 25-01-2012, 11:22 AM
  3. 1st CNC Mill for small machine shop
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:47 PM
  4. WANTED: Small CNC Drill/Mill
    By Mad Professor in forum Items Wanted
    Last Post: 03-09-2010, 01:28 PM
  5. Best software set for a small cnc mill ?
    By NICKMODELMAKER in forum Computer Software
    Last Post: 12-06-2010, 11:20 PM
