05-06-2010 #25
Link is http://resources.renishaw.com/downlo...en&inline=true
Probably a little lighter than I want, but not much. The sort of thing I want to make may be (examples to show range)
Frame side in aluminium machined from 2mm alloy plate, ribs "T section" 2mm by 2mm with up to 60mm unsupported.
Compressed air turbine in titanium (a bugger to machine with anything) 26mm dia 6 grams weight - must be inherently balanced (hence need accuracy)
machinable castable wax model to try casting iconel model of same if titanium doesn't work.
The most common needs are accuracy and a really high spindle speed.
Mike
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
WANTED: Wanted - small bench cnc mill
By camhguh in forum Items WantedReplies: 2Last Post: 25-01-2012, 11:22 AM -
1st CNC Mill for small machine shop
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-09-2011, 10:47 PM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Best software set for a small cnc mill ?
By NICKMODELMAKER in forum Computer SoftwareReplies: 3Last Post: 12-06-2010, 11:20 PM
