Thread: Cheap Idea for a DRO
17-05-2010 #11
ISTR you can fit one or more PICs as required.
Congratulation John - that's more than I ever did :LOL:I'm getting to understand your assembly code
From memory, the Txsyn timing is a simple grab a slot when ready affair with a different delay based on chip position to help prevent collisions.
(i.e. if Txsyn = hi, delay X.Y,Z or W recheck Txsyn if hi, pull txsyn low and transmit)
Is the vernier being switched into fast mode correctly? Different makes/types of scale have different clk/data line switching sequences so some don't work with out mod'ing the code
Are you powering the scales from the interface or the on-board cell? (I replaced the cells with a ~1uF SM cap) What voltage are you ghetting across the PSU red-led?
The serial port is running at 115,200 baud, so screening and good earthing is advisable. And, it derives its -Ve from the PC so, just check that's working OK.
Website idea.
By qwertyjon in forum General ComputingReplies: 8Last Post: 05-04-2014, 03:29 PM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Why they don't want to accept my idea?
By hoezap in forum Tool & Tooling TechnologyReplies: 5Last Post: 14-07-2012, 01:15 AM -
business idea?
By homer93 in forum Marketplace DiscussionReplies: 7Last Post: 01-06-2012, 12:56 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
